Absent Minded Farmer
- Location
- Gehl Country, Wis.
Well, I didn't do anything wrong at least. All the maintenance I did was done the way it should be. No issue with changing out the igniter, either. So, it seems someone from the high falutin local big time HVAC company we called last year, this time, was messing with the flow set screw on the regulator in the furnace. The small time service guy who worked on it today, the same guy who put the furnace in several years ago, told me that those regulators are identical between several manufacturers. When he sets that screw for a furnace hooked up to natural gas, he always puts the notch in the screw perfectly vertical. Puts a little scratch in it at the top next to the notch. He found the scratch pointing at about 5 o'clock. Set it back to where it should be & we have heat again.
What I'd like to know is, is it possible that the screw was set low enough to cause the regulator to starve out & not light the furnace when there's a large demand on the system & the pressure drops? Seems like a shiesty move by a major HVAC company that would want to keep coming back for a routine service call to keep their pockets fat. Kind of like a jack leg mechanic pouring oil on an engine to get you to pay for something that didn't need to be fixed in the first place.
Mike
Mike
