Brucester
- Location
- Excesior Springs, Missouri
I recently added a manual fuel valve (near the glass bowl filter) because my stock fuel valve is leaking when the screw is in the closed position. Before I attached the manual fuel valve, I checked to see if the stock valve was leaking in the “open” position. Gas level was above the inlet screen in the tank. After two hours, I rechecked the stock valve and everything was dry, so I installed my 1/4 turn fuel valve. I checked the stock fuel valve this AM (about 24 hours after the manual valve was installed and it is leaking droplets about every 30 seconds. This is with the manual valve in the off position. Guys, I’m 83 years old and I’m really not up to replacing/removing the stock valve. My question is does any one know of a pliable gas-proof compound that would seal the stock valve’s screw, from the outside of the valve body, with the screw out in the on position. This isn’t my usual method of repair, but again I’m just too darn old to wrestle with removal of the stock valve. Any helpful suggestions would be greatly appreciated. Thank you.
