GAS TANK ON 641
N.L. (MS)
I HAVE A SMALL HOLE IN THE BOTTOM OF MY GAS TANK. ARE THERE ANY WAY TO FIX IT. ie BRASS, SOLDER, WELDING IT, WITHOUT BLOWING MYSELF UP??? I THOUGHT ABOUT TAKING IT OFF AND BLOWING AIR IN IT TO RID IT OF FUMES FIRST, OR MAYBE FILLING IT WITH WATER. ANY SUGGESTIONS.
If its a small pin hole just use a tank liner and be done with it. The only safe way to fix a tank is have some one else do it unless you have the right equipment to do it. Welding etc is unsafe unless you know 100% what your doing and even then its not real safe to do
Hobby farm
Do you know for sure where the hole is? My tank was cracked in one of the spot welds where the rear mounting bracket was welded to the tank. I drilled out all of the spot welds and took it to a welding shop and he soldered the crack up. He was familiar with the Ford tanks and he said you have to be careful and not get it too hot because the 2 halves (upper and lower) of the tank are soldered together and you're up a creek if you melt that solder. He filled the tank with water or an inert gas (I wasn't there to watch) before he soldered it. I strapped the tank to the mounting bracket when I put it back together.
I patched a hole in the bottom of a gas tank on a Chevy S-10 several years ago. I got the kit at the auto supply store. It was a two part epoxy and it worked very well. You might check there.
I used a permatex patch on mine. Mix up a black epoxy and cover it with the membrane then overcoat. Seems to work well and can be painted.
jb
Lotsa ways. Most places sell gas tank epoxy sticks.. If I do that.. I like to tape a self tapping sheet metal screw and slip a small nitrile ( fuel resistant) oring over it and screw it into the hole. then put the epoxy patch over it. ( this works GREAT on oil pans when you get a chip from a rock or .. etc..)
Soundguy
