Gas Tank Rusted inside
Don Yoder
I have a 1941 to 1943 Farmall A that I am restoring and it did not have a gas cap on the Tank when I purchased, it appears it has been outside for several years and the inside of the tank surface is all rusted. Any one know how or if it can be cleaned up with out cutting it open. Is there any way to use a rubber container inside of the tank,a plastic or epoxy coating the will work with Gas once the inside is cleaned up.
May have to find a good used one!
add small pebbles or nuts and washers strap it to another tractor wheel and drive for an hour or two.
Kreem sells a complete liner kit. (ask at a motorcycle shop)
ive used a 1 foot length of chain in a tank and shake the heck out of it than clean it out, you can buy gas tank liner it works well just be shure to get all the loose stuff out, you might go to a radiator shop and see if they can dip it in an acid bath, might be an option. good radiator shops are getting harder and harder to find these days
Get some red Kote at Napa , swish it all around ,drain Excess back into Qt container , One qt, did me 4 tractor gas tanks ,,.Allow double the drying Time ,, Also when complete put a 1/4 copper tube 1 inch hi in the Sediment bulb drain ,,That will always assure that You will havce one inch of gas in the tan k ,,that has trash in the bottom , drain that out every 3 yrs .. and pressure wash ...
Muratic acid will definitely clean it but you need to neutralize it after you drain it and then get the coating on as quick as possible cause it will flash rust pretty quick. A less toxic mix is phosphoric acid which does the same thing but takes a little longer. Paint or hardware stores should have either.
NAPA auto parts sells a 3 part kit, (# quarts)
that i"ve had good luck with on Wisconsin
engine tanks, 1 kit will do several 2 gallon
tanks. It was (approx.) $52 last fall, pricey
but worth it to me!
Have a Farmall F20 that the tank rusted from old gas left in the tank. Tried cleaning with stones in the tank and shaking by hand until as much rust would come out. More rust eventually came loose and plug the fuel line again. Put more stones and bolts in tank and straped tp another tractor wheel for an hour. Purchased a product from EASTWOOD called Fast Etch. Put in tank and let it do it's stuff for about an hour. Drained and rinsed tank with Acetone. Re-assembled and filled with gasoline. So far the gasoline is clear of rust. Time will tell if this is working.
