Background: I got a 72 1520 gasoline from a friend recently. It was pretty rough and not running well. Got all the rust I could out of the gas tank with a magnet, blew out the fuel lines with compressed air, new fuel filter, sea foam carb cleaner, changed hydraulic/trans oil and filter, engine oil, and installed a new ignition switch. Carb is shot though, leaking at the gasket and needs a rebuild or replacement.
Questions: has anybody here converted their gasoline tractor to propane? Did you buy a carb designed for propane or did you use a regular carburetor? How was the performance? Did you see a noticeable loss of power? Did you see any benefits over gasoline?
Thanks,
Carl
Thanks,
Carl
