Paul Beck MN
Hi all. First time here. I am trying to assist my girlfriends grandpa in getting his 4400 running. It ran last year he said. The carb has been gone thru and there is ignition. timing is correct as per the top dead center and where the rotor points to #1. Have also verified valve operation. Im leaning tword compression, i am bringing our shops tester out to the farm tonight. What it does is crank, and even with your hand covering the carb opening will not fire. It does not even get the plugs wet. It has great suction on my hand. I took the carb off and sprayed eyther directly up the intake. Still wouldnt. It cranked faster but thats it.
Any other ideas guys???
Thanks!
Paul
Not familiar with 4400, so just general comments:
(1) great suction on hand: if your hand didn't get wet, not getting gas;
(2) same for plugs not getting wet;
(3) cranking faster with ether indicates some firing but not enough to run...
(4) timing probably (repeat, probably) OK if no dismantling done on ignition, no kicking back on starter, coughing back thru carb.
Could be lack of compression, but it'd have to be really bad to keep from running at all.Updraft carbs are bears to try to prime thru.
Try pulling plugs, squirting a little gas in, replacing plugs and trying; if not running for lack of gas should act like flooded (rapidly spinning on starter to clear out excess gas, then slowly fire and run until gas burned up). Good luck.
pull seat and follow gas line to tank. the one I used to have had a inline fuel filter it would get plugged and would not start
