generator troubles
jakey756
Hey guys
Well my work on the B continues and now its the generator thats given me troubles. I took it apart cleaned it up got it so it would produce some power. It doesn't produce much power but it does produce a little. I cleaned all the connectors and that didn't help. Could it have something to do with the field connector on the generator? Do i need to reset the brushes? If so how do i do that? I don't even think its producing enough power to get past the cut-out relay.Any help or any thing i missed would be appreciated.
Thanks
jake
Found some posts in the archives that are helpfull. Don't want yall retyping everything so just ignore this. Sorry for any inconveniences
Jake
While you're swampin' through the archives, you might find it just needs re-polarizing, and there's plenty of stuff in there on that. JohnT has a post he puts up pretty regular that's a good step-by-step and real helpful on locatin' problems like you're havin'.
G'luck, and keep us posted.
I LOVE alternators! Not sure sandpaper in points is good. Seems like sometimes a little grit gets caught in between. File don't do much better. If I clean points and then OK, I shut er down and change to new ones. Pull a 3X5 card through new ones in case oil is on them.
