Getting 730 gas to run smooth
old red guy
I have cleaned carb on 730 that hadn't ran for several years once by bead blasting, which resulted in hard to start and not running on No. 1 unless throttled up. I got good advice on forum about idle ports still needed more cleaning by soaking in carb cleaner, so I cleaned it again, which still resulted in hard to start and back firing alittle at high idle. Took carb off again and did everything I could to make sure all air passages were clean with air and carb cleaner. Tried tractor today, it started easily on full choke and ran smoothly at idle and high idle. I thought I my problems were solved until I saw that the choke was still half on. I pushed it all the way in didn't want to run at slow idle and backfired some at high idle. Need some suggestings please. Thank You
A dunk in carb cleaner and a blast of compressed air is a waste of time.
A set of drill bits from Robert's Carb, pulling the steel balls and using a torch tip cleaner on the six idle ports is required.
You can check those passages for flow in a parts washer with some careful aiming of the nozzle and looking in the proper spots.
Your passages maybe open and your condenser going bad. I've had more then a few act like that and first thought it was the carb. turned out it was the condenser.
