getting my engine started
Anonymous-0
What is the best way for getting my "engine" Started and how do i satisfy it when i get him started? strategies acctepted, -- Dan
before you get worried, just know that IP addresses do NOT indicate the identity of a person. No and's, if's, or but's.
forgot to mention in my other posts- Ive seen the same id numbers before with different people but i thought each person was given a specific number?
Dan ---
It's best to say the make and model of your tractor when asking a question......I'am a Farmall man........they don't like a lot of choke......set the brakes and lock 'em......be sure it's out of gear.....set the throttle about 1/3...pull the choke 1/2 way out....turn the gas on under the tank...turn on the ignition...push the starter ...as soon as it starts push the choke in...if that doesent work, try differnt settings with the choke....they are all a little differnt.......good luck...Don
sounds like what "the man" really needs to know is how to get "her" engine started, and how to satisfy "her" once he does.
Hint: It starts by NOT being "THE man" but by being "A man"....
Nope, IPS are just internet connections and will ususally change every time you get on, and are sometimes the same by coincidence. Gets discussed alot here
Oh boy! This is going off the deep end. My cousin used to say the ladies would say "who are you going to satisfy with that?" He'd say "myself".
Right,Farmalls do not like alot of choke. I could start mine with no choke but had to use the choke to keep the running untill the warmed up. The farmalls were a 1939 M and a 300.
steveormary
