Gill Box Blade Bolts
I have an old 5-foot Gill Box Scraper with the hinged back blade that needs some steel work. Does anyone know what size & type the bolts are on the high carbon blades? They look similar to plow bolts but they're so rusted, I'll need to cut off with a torch. The reason I'm asking, I have to replace some rusted-through steel right above both cutting blades--will need to insert a 4" wide or more strip all the way across, and the cutting blades need to come off to do the work properly.
Thanks for any info or suggestions.
Kevin have a parts book somewher but unable to find the thing this morning. I am ALMOST sure that if you get 5/88 X 1.5 in plow bolts you will be o.k. Should take six twice if you are memoving both blades..Land Pride and Gannon uses
both 5/8 and 3/4 but I think the gill used 5/8. If I can find the book will double check..Hope this helps Jery Watkiins
