Global warming?
rrman61
Seems like you guys up north are still getting some winter weather.How"s that global warming working out for you guys.Will get up to 75 down here in La.If you listen to some of these climate change people,should be about time to plant corn LOL.
Yeah I"d like to see these "climate change" supporters explain why we have a blizzard warning here in MN and its supposed to drop to the single digits and 30-40mph winds tonight.
southern Michigan had 70 and 80 degree days last March and it turned out to a miserable hot and dry summer , I'll take a cold march in exchange for a normal summer .
Yep,I was working oat ground a year ago at this time. This is closer to normal. We had snow on Mothers Day two or three years ago.
Warm, ha!! I dropped a piece of wood today on the ground when I was loading the OWB. Sounded like I dropped it on hardwood flooring or concrete.
rrman61. I am in south LA. I think we talked on the phone before about a 1550 oliver. where are ya located? got any tractors? Travis here 337-852-1703
Kinda below normal. Toledo 13 weather man said we had the coldest average temperature for February on record and March was headed that way.
I don't think it's global warming were i am, 40mph and blowing snow, and its 20 degrees, in negative with windchill.
You must not live too far from me. No school here on this end of the county because of ice. Very little ice in Wauseon.
A year ago today I was getting my drill ready to plant oats. Once the snow stops today, I will have to go out and blow 3-4 inches of snow off my driveway. Be lucky to plant oats by mid April this year in NE WI. Al
Yes... and now I see that our President wants each major project to be evaluated on its impact to climate change. Probably will need another Gov't agency for that - of course!
This tractor was in the shop 10 days ago, there was probably even more snow on it but it was finally above freezing today for a little while.
All you boys" griping about too much snow, be glad you"re getting it. It was 90 here in central Texas today and certainly too dry to even plant a hay crop. The only ones making any $$ are the feed and fertilizer stores.
Nothing I want to sell tbird.But if you want to try your luck on that 1550 we talked about,I can give you some directions.Gotta warn you though;the owner thinks its worth more than it is.Far as I know its got a bad knock{ran low on oil].Tach shows less than 2000 hrs though.I'm in cecelia,20 miles east of Lafayette.337-371-8440
