glue for plaster
I stumbled over a plaster dog statue the other day and turned it over breaking it into a dozen or so pieces. I want to try to reassemble it but I only want to do this once and I want it to be good and strong. The plaster is gray in color and porous. I went to ACE and they recommended contact cement that seems to be being sold mainly for attaching laminates to particle board. Do you think this will work? Any other recommendations?
I guess it is. I bought it at a yardsale and can tell it's one of those statues you make by filling a mold, waiting and pouring out the extra. I'll have to check to see where I can buy plaster. I just come in from taping together the pieces (his head broke off and nose broke into a bunch of pieces). I was wondering about using mortar mix or hydraulic cement to fill or cake to the inside while the tape holds it together. But it never occurred to me I could get plaster. I guess that would adhere to the pieces already there.
Duco cement will work very well-and still give you time to position things after you start assembly. Contact cement will NOT give you time to position things. Greg
I used gorilla glue. Great for poor fit up or tite fit. It will spread the joint when it dries f you don't clamp or tape. Plumbers putty to scaffold odd shaped parts, then peal it off when dry. Masking tape for clamps. I thought of filling statue with hot stuff foam when done, for added strength. Not there yet. Good luck! joe-
