notjustair
Couple of days ago I posted about the rear pinion seal on my grain truck - this is the same truck. It has a 270 6 cylinder in it.
Decided to change the manifold gaskets on the truck before harvest. Have always had trouble getting it to seal as the combination manifold is a little out of true. I'd like it to sound somewhat respectable at the elevator!
Pulled off the manifold and found a little antifreeze in the exhaust port of 2/3. How can it get there if it is not getting into the combustion chamber? I just did the oil pan gasket about 50 miles ago and no water in the oil. I will pull the plug and make sure, but unless it started happening just this week it isn't going that direction.
I'm struggling to understand how it is getting there. Cracked head? This truck has eaten head gaskets every few years since it was new (I am third owner with all records). It was blown when I bought the truck between 5 & 6. It seemed like maybe there was a defect on the head there but I was in a rush and slapped it back together. I know when it goes this next time I need to take it in and have it checked. The last owner had it for 20 years and took the head in and had it checked and rebuilt.
I'm just puzzled about this coolant. I'm also more than a little worried. This was the third truck in line for harvest in a week and just got bumped up to truck number two as a result of a separate breakdown. I think I will put some sealer in the radiator and hope it makes it a week. My head guy is good but there isn't a snowball's chance he could do it in a coupe of days.
Is it possible it is just coming out the exhaust? How? I might add it runs like a top.
