notjustair
Couple of days ago I posted about the rear pinion seal on my grain truck - this is the same truck. It has a 270 6 cylinder in it.
Decided to change the manifold gaskets on the truck before harvest. Have always had trouble getting it to seal as the combination manifold is a little out of true. I'd like it to sound somewhat respectable at the elevator!
Pulled off the manifold and found a little antifreeze in the exhaust port of 2/3. How can it get there if it is not getting into the combustion chamber? I just did the oil pan gasket about 50 miles ago and no water in the oil. I will pull the plug and make sure, but unless it started happening just this week it isn't going that direction.
I'm struggling to understand how it is getting there. Cracked head? This truck has eaten head gaskets every few years since it was new (I am third owner with all records). It was blown when I bought the truck between 5 & 6. It seemed like maybe there was a defect on the head there but I was in a rush and slapped it back together. I know when it goes this next time I need to take it in and have it checked. The last owner had it for 20 years and took the head in and had it checked and rebuilt.
I'm just puzzled about this coolant. I'm also more than a little worried. This was the third truck in line for harvest in a week and just got bumped up to truck number two as a result of a separate breakdown. I think I will put some sealer in the radiator and hope it makes it a week. My head guy is good but there isn't a snowball's chance he could do it in a coupe of days.
Is it possible it is just coming out the exhaust? How? I might add it runs like a top.
I would guess there was a crack inside the exhaust port causing the antifreeze in the port. The manifolds, especially the exhaust manifold can be warped, try finding a replacement. The head can be warped between 5 and 6. When you have the head off, clean the mating surface real good, an electric orbital sander works best, use a good straight edge and a feeler gauge to check for straight and level. Check between each cylinder diagonally in both directions, Straight lengthwise at three locations, and at 90 degrees between each cylinder. We used to check with .001 or .002 inch feeler gauge. I've seen the space between cylinders with a small series of cracks like a spider web, they could sometimes be machined, but may need some kind of welding process. Our shop used a tapeded threaded plug that we called "cold welding", but that is harder to find now, I can still get the taps and plugs from NAPA, but there is also a system called locknstitch at http://www.locknstitch.com that has a kit to fix cracks of various types. To check for cracks completely you will need the head sandblasted and magnafluxed. A crack inside a port may not be repairable, and if it is not affecting performance could be left and just keep the coolant up. Thermal cleaning with steel shot can have the added benefit of revealing cracks as a line of rust, look at http://www.enginebuildermag.com/Article/86770/media_and_solutions_for_cleaning_engine_parts.aspx
You are making me feel better Dennis. There was some kind of defect between 5&6 that probably needs to be welded. I am betting when she goes it will be right there.
Seems kind of odd, but I kind of hope for a crack in the port. I have a really good head guy that works miracles and even if it is terminal I would just run it like that. Seems odd that it cracked, though. The truck never runs hot. Must just be age. It only has 77 thousand miles, but it is a wheat truck from 1958. Those two things dont add up to an easy life.
I hate that potion like the wind, but I think I will dump some kind of gasket/head repair stuff in there.
you might also see if you can find a spare head, wish i could help back in the 70's i worked at a oilfield repair center to put myself thru colledge those guys must have had 50 of those engines all ready to go, i dont know what used them in the oilfield, as that would be a little overkill for a pumpjack but they had a bunch of em on something,anyway have the head done and ready then you can just swap heads and keep going , rebuilding the original if possible when time and money allows
Never mind - there was water in the oil. I don't know what it is with this truck and head gaskets. This is the shortest life at a year and a half. Oh well, it is too wet to do anything anyway. I should have the number for the head gasket memorized!
Some cracks can be from freezing, too. That would happen in the Allis Chalmers B and C block because the cast iron between the sleeves was especially thin. Some heads were known for cracking in certain areas, and could almost be predicted. We didn't get enough GMC engines from that time period to know if there were normal problems, I guess that was good.
Check this blog, it looks like they crack along a casting line in the exhaust port http://www.jalopyjournal.com/forum/showthread.php?t=772356&highlight=gmc+270+head
