Gonna cut it up!
Im pretty handy with diesel engines as Ive got several.Ive got 2 D-2 cat crawlers.One is the early model and it runs perfect.I cleaned the pump up from years of sitting,changed the filters bled it and she fired right up.The later model is nother story.Took transfer pump apart and cleaned it and drained old fuel out.Then I put in new filters and fuel.I took all injecter lines off and blew them out and left them off then opened up pump bleeders.Ive spun it several times 10 or 15 minutes,,,no fuel.Whats up? or shall I warm up the torches? Frustrated- Hoss
have you tryd pressureizing the fuel tank with compressed air to force the air out? i have had to do that many times to get fuel into a pump.
I was thinking of puting a little pressure to it.Yes the rack is free.had the cover off the side and back of gov. Hoss
hello Hoss in Me, bleed the fuel pump ,fill filter tower with fuel ,bleed injector pump ,bleed injectors ,make sure fuel tank cap breather in clean and not blocked ,bruce oz
What year is that D2 that you are looking at disposing of? I am looking for a good D2 head if you end up disposing of it. My email is open.
THanks.
