Gooseneck Hitch
njfarmer
I would like to put a gooseneck hitch onto my 1999 ford f350 and am looking for suggestions on which brand of hitch to put on. I don't have to worry about the bed being in the way because it is already off of the truck to undercoat the frame so a ridged frame one would work. Any Suggestions?
(quoted from post at 10:45:39 04/04/12) One of our local farm stores was selling these type of hitch plates for around $100. I'm assuming your F-350 is a flatbed.
Hitch plate
Is that one of those that simply bolts to the bed of the pickup box? A TRUE gooseneck hitch bolts to the FRAME. No way would I use one of those plates.
It's gotta bolt THROUGH the bed to the frame or UNDER the bed, I'd think.
Only an idiot would bolt a gooseneck to the bed. It would tear out of there the first time you hooked to anything.
I've made several of my own. 8"x3/4" plate bolted to 1/2" angle iron, bolted to the frame. Drill hole in center of plate for shank of ball, nut welded to bottom of plate, use a pipe wrench to take ball on and off.
That being said, if I were gonna buy one, I'd go B&W.
Ben
I guess you could mount it any way you wanted to, but anyone with any sense would bolt it directly to the frame. I certainly wouldn't want anything but a true gooseneck hitch. . .
What's a "true gooseneck hitch" in your eyes?
For decades, people were just laying a 3/4" to 1" flat plate of steel across the frame rails on their truck, welding it down, punching a hole in the middle, and installing a ball.
That is a TRUE gooseneck hitch. These no-drill hide-a-ball things didn't come along until about 15 years ago.
(quoted from post at 08:07:52 04/06/12) What's a "true gooseneck hitch" in your eyes?
I have to laugh :lol: Did several this way years ago and just welded the ball to the plate.
My GN hitch is an 10" piece of 1/2" thick channel iron welded between the frame rails. Gets the job done and has hauled many a heavy load.
The way I looked at it when I bought the B&W, was that IF the hitch failed for whatever reason, and somebody got hurt because of that failure, I wanted to be able to say "I didn't build it".
How do you tell the "max load" on a hide-a-way hitch... just curious, have one too but never pulled anything of sizable weight with it.
Thanks, they cut a whole in the bed and mounted it below, refastened the bed, them x-lined it...., just barely showing the parts that pop up. Been looking around can't find any markings, but talked with the dealer,he thinks they installed a 25K/6.25K, which is plenty for me. hate to pull off (at least one side of the bed ansd look, but may not have a choice to be safe...)pewwww!!
I've had three different kinds of hiches and the BW is the best one by far, make sure it is installed by someone that knows what they are doing.Talking about hiches ,when the goosenecks came out in the 60's they would do the plate thing in the bed cut a hole in it and on the trailer there was a 4x4 plate mounted with "C" clamps on the goose neck with a huge bolt welded on to it they would screww the nut on and back it off a couple of turns place it over the hole and weld the nut to needles to say everything wallerd out,there was a recall and hence the ballRoman.
