My tractor is a combination of years. It has a 1949 engine mounted on a 1951 Frame with Sherman transmission. I've been working on it for over 2 years now. New brakes, Clutch, carburetor, PTO shaft, water pump, radiator, hoses, alternator, etc. etc. I am now working on the governor. The engine has a three arm governor on it (type were throttle rod is over engine and comes down vertically) but the throttle rod setup is for an 8's 2 arm governor (from dash under intake/exhaust manifold). The rod that comes from the throttle is wire tied to the curve of the vertical arm with the spring on it. It kind of works but the response is very poor. Note: there is a Proof-meter but the cable goes to the clutch housing, not to the governor. Cable for proof-meter does not turn so it needs work too. To fix both issues, I'm looking at replacing the 3 arm governor with a 2 arm governor. I see lots of comments about the poor quality of after market governors. I can get a after market 2 arm with proof-meter connection on line for between $150 and $400. Any better than others or are all made by same offshore company? Would I be better off trying to locate a used 2 arm that has the proof-meter connection and rebuild it? I see used 8N governors with proof-meter connections for sale from $140 to $200. Rebuild kits from $100 to $180. Looking for suggestions., experience etc. Thanks for reading
