hayhay5757
To 20 Hade swing wt type gov. found wt in oil pan bought new ball type governor installed / arm does not function AT ALL (have had it apart 3 times everything is free / have disconnected all linkage from arm start operate throttle manually "0" movement / moved adjustment screw from all the way in to out in my hand still "0" movement / also with engine running pulled back on arm revved agen no movement/ outer & inner arms are tight on shaft / the outer disk on governor moves freely all three times i have had it apart / third time apart checked to make sure i put in shim
What the Hell am i missing "HELP"
