Gpowerblock
jdo
can someone tell me exactly where it is stamped on the block,someone has been grinding on my block and i can still see some type of lettering but can not make out what it is.Is there some other kind of markings on top of block
Have seen a few times before where the rules outlaw power blocks, so people grind off the famous letters. Then most do not know that it is one except for a few.
Easy to tell, few ways are: no petcocks,also there is a raised ridge on outer portion of block where top outer head stud goes. Not hard to pick out
Good to see you Juggs!
Is it possible to drill a G PB for petcocks, like an A? Are the plugs angled or straight like a stock block?
Depends where you want to put them....down on the bottom thru a head stud, yes. There is a spot on the side where there is no water passing thru, but hard to tell where. I do have a cut-apart PB here I'd have to look at or show you.
