Grandpa Love
crsutton81
Thought I'd share this for what it's
worth. On the 1 wire Cub alt post
below, we had a 1 wire alternator on
a sprayer wired similar. My starter
generator man fixed it like this. It
worked very well. It charged at low
rpms. There is a diode in the black
pigtail wire coming out of the top.
I ran the charging wire back to the
key switch. It never discharged the
battery either. Hope this helps.
<img
src=https://www.yesterdaystractors.com/cvphotos/cvphoto110068.jpg>
That will work.
My concern though, the wires are not secured in the gray piece. If they vibrate loose, or get pulled out, they can short or get plugged back in backward.
Solution would be to add another pigtail harness that snaps in the extension harness, or cut and permanently splice the original wires. All it is doing is adding the diode to the circuit.
Is that two separate circuits running through the grey connector or are they all connected inside? I'm about to attack my alternator wiring and I have that same alternator setup. Steve
The wires are separated inside the gray connector.
Its purpose is to be a simple fix, to add the diode to a system that for whatever reason, didn't have the diode. Unplug the original harness, add this one, plug everything back together.
Without the diode, the alternator will back feed the ignition circuit and the engine will not shut off when the ignition switch is opened.
I honestly don't know how to answer your question. I want to think it's 2 circuits combining into 1. He primarily fixed it like this to make it start charging at a really low rpm. It worked good.
(quoted from post at 21:55:32 12/06/21) I honestly don't know how to answer your question. I want to think it's 2 circuits combining into 1. He primarily fixed it like this to make it start charging at a really low rpm. It worked good.
Both yours and grandpa Love's alternators appear to be 3-wire alternators not a one wire ones. If yours was a one wire it has been re-wire to be a three wire, which receives outside excitation to start it charging at a lower rpm.
The battery wire is one circuit. The second wire with the diode in it is the excite circuit and goes to a switched power source, like your key switch. The diode prevents back feed from the alternator to the switch which could keep the engine running with the key off in some cases. The third wire (circuit) is the voltage sensing circuit it connects to a major voltage source to provide system voltage feedback to the voltage regulator in the alternator. The alternator battery terminal is one place it can be connected, the solenoid battery lug is another place. The short harness with the diode is not combining any circuits.
Only a battery wire is needed on a one wire alternator.
