Grill;e Panels
8N grille panels were secured at the top edges with spring-loaded pins. 9-2N grille panels had three rigid pins. How did that arrangement work for opening and closing? Were the hoods different on the front lower edges? I've worked only with 8N's so far and am not familiar with the gray models.
Thanks
Dave Erb
New Holland, PA
9n/2n didn't open without unbolting the bottom, unless forced with a screw driver. Which the previous owner of my 9n did quite often from the looks of my hood.
What do you do about the radiator neck,mine is in a position where it wouldn't tilt open unless completely unbolted.I remove the bolts at the dash,and at the top of the doglegs,and the hood lifts right off,with the grille.---lha
