Another issue with my 300U. When cranking, the starter makes an awful grinding noise. This isn't the high pitch whine of the starter gear spinning against the ring gear and not engaging. Everything is cranking and not slipping. It just sounds like there's a bag of rocks in there with it. The sound is definitely only when cranking and sound like the gear engagement.
The starter has the new style gear and it appears to be almost new. Cranking the starter on the bench, the gear appears to move correctly. I measured the distance from the bellhousing to the ring gear, along with retracted and extended starter gear positions and didn't find anything unusual.
This led me to suspect the ring gear, although it didn't appear badly damaged through the starter hole. I split the tractor, pulled the flywheel and got a new ring gear. The new gear looks very similar in tooth profile, and other than the front of the teeth being chewed up a bit, the old one just doesn't look that bad. I've seen much worse looking gears that still work, or maybe have trouble engaging, but none that make this noise.
I still intend to install the new ring gear, but am concerned I'm missing something else and will still have the noise after bolting everything back up.
Looking at the wear pattern on the ring gear, it feels like the teeth are engaging at the tips. Normal?? If this was a SBC I would be adjusting shims.
As long as it's all apart, is there anything else I can check? Other ideas?
