grinding wheel ??
Anonymous-0
its 5 inch dia. , threads on to a shalf????whats it for & whats it called, ill try to find a new home for it. thanks ill post picture in help I.D. , dont think i know how to put pic here!
beleive i've seen these in catalogue. called grinding plug. used on large vertical shaft air grinders for removing casting flash in foundries and for joint chamfering in some welding operations. i may stand corrected on this as i've been known to be wrong
The grinding wheel for sharpening a sickle mower is double cone.
This stone is probably that one for cleaning up rough castings. Large would be appropriate for that. Look at 8732A49 at www.mcmaster.com
Gerald J.
I would toss that wheel in the trash, AFTER I broke it with a hammer. Old wheels get brittle over time, especially if stored in a damp area. Not worth the risk of getting hurt, to use old wheels.
If the threads are 5/8'ths X 11tpi, it'll probably thread onto a standard angle grinder. They don't go bad from sitting, but if the balance is bad, or if there is a crack, Chuck it!
Old grinding wheels do not suffer from age.Im still using wheels I bought 1n 1970 on my Belsaw tool sharpening machine.You can test wheels for cracks by ringing them.Suspend the wheel on a dowel and tap the edge lightley with a steel tool.A sound wheel will ring, a cracked wheel will not.Many wheels are out of balance and will vibrate.Not problem on rough work but trouble when sharpening tools.Out of balance wheels can be detected on a simple mower knife balancing cone.Out of round wheels can be dressed.Cracked wheels are caused by dropping.Import wheels are all suspect.Always stand aside when starting a grinder,they seem to always let go then if cracked.
Ive used every sharpening method used.The 4 inch angle grinder lets you watch the grinding process.I clamp the knife on my welding bench and sharpen.Dont mess with cheapo grinders or wheels.
