Stan in Oly, WA
I'm installing an outdoor light on the opposite side of the patio from my house. I'd like to put an outdoor outlet there, too. The power to the new location will be supplied through a 12/2 w/ground underground cable from an existing outdoor light nearer the house. If I had been paying more attention, I would have noticed that light where I'm taking my power is on a 12/2 ungrounded cable.
There is absolutely no way to get an underground ground wire to either location without tearing up so much concrete and brickwork that it's simply not an option. If I had foreseen the problem eighteen months ago, I could have run a ground wire to the distant location with considerable difficulty, but at least it would have been possible then and now it's not. (External conduit won't work---it would literally have to be up in the air.) Also, there is no plumbing in the area to use as a grounding point.
I'm okay for the distant light which will be no worse than the way the existing light is wired (no ground) but I don't know what to do about an outlet. I've thought about putting an ungrounded outlet there so it would not suggest that there was a ground. Is there any other, better way to do this?
Thanks, Stan
Thanks, Stan
