George by Geneva, NY
Well, I went into the unknown, started to remove belt pulley so as to check for plugged drain of oil back in to reduction gear case. Tractor is sn under 10,000. Took snap ring off splined shaft, moved the pulley out about an inch and it stopped. I did too, as I now realize that the fork has to be loose or removed, maybe something else to free it up. Owner manual no help. Anyone out there that can give me info on what has to be done? One thing for sure I do not want to break anything, I was hoping for a quick off, clean the drain hole and put it back together.
