Hand Clutch
Anonymous-0
The hand clutch on my Allis Wd45 for some reason will not stay ingaged when pulled back. Nothing looks worn out. Is there some check list that would tell me why it is doing it? Would too much oil in the chamber cause this? Not sure how to cure this. Any help would be greatly appreciated :)
It is hard to explain here but in the I-T manual it explains how to adjust it so it will snap in and stay in place. That is the AC-11 manual by the way
The clutch is out of adjustment. I can't explain it to good.....best thing is to get a manual that shows you how. It is a wet clutch....its always in oil.
You can go back a few days for my detailed explanation..........or pull the battery and box, the cover underneath.....LOOSEN, not remove the two bolts at three locations around the clutch, and remove equal number of shims at each location to tighten up the clutch until the hand lever snaps over center. Shims are slotted, so you can loosen, not remove the bolts, and pull shims. If shims are gone, it is time to split the tractor and rebuild the clutch with new plates and shims. Oil level has nothing to do with your problem- it is shims or worn clutch plates.
(quoted from post at 01:54:29 10/28/11) You can go back a few days for my detailed explanation..........or pull the battery and box, the cover underneath.....LOOSEN, not remove the two bolts at three locations around the clutch, and remove equal number of shims at each location to tighten up the clutch until the hand lever snaps over center. Shims are slotted, so you can loosen, not remove the bolts, and pull shims. If shims are gone, it is time to split the tractor and rebuild the clutch with new plates and shims. Oil level has nothing to do with your problem- it is shims or worn clutch plates.
I had the same problem. After removing some shims I still had that problem. Ended up checking the gap between the clutch plates and found it was not even. My Agco book says there shoud be .065 gap. I ended up removing one bolt to make it easier to remove the shims. Hope this helps.
