hand cranking a CA
i have a 53' CA that the starter is acting up on and i was wondering how hard it would be to hand crank it. i've had to hand crank a 3 cylinder lyster but that had decompression valves. what do you do? roll it till it hits a compression stroke and then yank? just wanted to ask so i don't lose any teeth. thanks
If it is tuned up well and easy start yep it can be done, but if you how the crank wrong or do it wrong it can/will brake your hand or arm and you will then go to the hospital. BTDT on a B years ago and I was holding it correctly but it still got me wore a brace on my right arm for 6 weeks from that
<a href="http://s239.photobucket.com/albums/ff293/ovenstu/?action=view&current=HandCranking.jpg" target="_blank">
HandCranking.jpg" border="0" alt="Hand Cranking
</a>
Pedal lock refers to a WD.
Good advice from Dick, dont ever wrap your thumb around the crank handle, cup the handle in your hand and pull up quarter turns. Be patient, I messed up my hand pretty good doing it the wrong way.
I had a C that I cranked a lot because the charging system didn't work. I would stand on the right side of the tractor, put my left hand on the side of the grill, bring the engine slowly around till the handle was pointing down at about a 45 degree angle and then pull it through about 90 degrees across the bottom of the stroke. It would turn over pretty easily. If I had parked the tractor where the ground rose to its right I would have to kneel down in order not to be too high up to pull it through comfortably. I just traded the C for a Farmall H or I would take a picture to show what I mean. Always make sure it's in neutral before you crank. It was my first tractor with a crank, so it took me a little time to learn where to set the choke and throttle to get it to start.
Zach
putting the tractor in 2nd gear and having someone pull the tractor and releasing the clutch is always a good and safe option to start it.
Much better to use High (4th) gear. Lower gears just make the wheels skid, and spin the engine unnecessarily fast if it does turn.
What throttle position would you use? I"d assume low throttle, but my B likes to start about 1/3, no choke.
