My "47 E-3 tricycle is fairly hard to steer. I need to double check this, but am fairly certain it is all in the spindles bronze thrust bearing. I keep it well greased. At least I grease it often..
Are those old bronze trust bearings supposed to turn that hard? I have often wondered in anybody has ever found a sealed trust ball or roller bearing to put in its place down there? Even if you had to machine out the pedestal a little bit it would seem like a good idea..
Even with no weight on the tractor it is fairly stiff turning, and when I pull with it and add #1000 to the middle and nose of the tractor it is really hard steering.
Thanks for any and all replies...
