Harvesting sorghum
Erik Ks farmer
Ok here it goes. I planted 40 acres of milo to mix with feed. I have heard through the coffee shop bs that a guy can cut it with a cornhead (real nice big heads). Is this a load or is there some truth?
A corn head would just pull the stalks down thru the stripper plates. Don't have sorghum around here but isn't it like a giant stalk of wheat? The whole stalk and grain head would just be pulled down thru the head wouldn't it?
Way back when they were raiseing milo around here (SW MO) the cut it with a regular head. The bed was set only low enough to get all the heads. I haven't seen any milo since I moved back nine years ago.
I'd check at an elevator--maybe someone local would harvest for you. I hunted pheasants around Larned; we walked an entire section planted to milo.
Larry in Michigan
Around 1980 an early snow put a lot of milo down in the area where I lived, mine included. I abandoned cutting with my L Gleaner with milo fingers/guards and hired a fellow that had an L Gleaner with a John Deere corn head on it.
However it was not a standard corn head but had been modified to cut the heads from the stalks. Worked slick as could be and salvaged so much more of the crop than I could get that it no doubt paid to hire the cutter.
Sorry, don't remember more about the set up.
It was a factory setup but it isn't a cornhead but rather a row crop head. Has knives like a head on a forage harvester and cuts the plant off.
That would be similar to the "Heston Headers" we would mount to our grain head to pick up downed milo. I was only a kid when we had them but I still remember them being a PIA to mount.
You can cut milo with a regular rigid grain head we cut hundreds of acres in SW Texas one fall. down by the Seminole and Lamesa area. With a 9600 combine. if it was down the row crop head would be the best choice or you might be able to get by on a small amount with a hume real and flex head.
If crop hasn"t gone down yet why worry about it? If it goes down hire someone to cut it that has a row crop header or a header with fingers and pickup reel. We use to run a JD row crop header it has cutter knives underneath with rubber corrugated gathering belts mounted on chains instead. A corn head has knives with finger chains and rolls. Those rolls will pull in way too many wet sticky sappy milo stalks you don"t want! A row crop header will do a much better job if your milo goes down from bad weather or ice though.
