hauling #44 plow
Johnny50
Can I haul my #44 plow behind the tractor with the tail wheel up in 6th gear for about 5 miles?
It is well greased. Will the hubs heat up?
I'd recommend letting enough air out of one side that the tire starts to bulge the sidewall. This will help alleviate any back'n'forth weaving that can get bad enough to damage something. The only trick is that you have an air tank at your final destination to air up the tire.
Tyler
I've done that!
Other things I've done that helped.... Use a short clevis. Won't unhitch right so don't plow with it but it whips less on the road.
I've also swung my drawbar over so that the furrow wheel traveled in the gravel berm.
Adjust the leveling lever (crank if a hydraulic lift) to let the plow close to the ground. This puts it out of balance and heavier on the rear lifting up on the tractor drawbar.
Still mine (equipped with Wobbldini brand wheel bearings) will whip. Have never been able to hit full speed with my longhood A. Would not dream of hitting the road without safety chains. That beast will come un hitched very easily!
