Hay barn more
grandpa Love
My wife agrees that the location along fence is no good. Bottom of hill and way off driveway. New plan. Build on top of hill right off driveway to tractor barn. Water will drain good. And easy access. Built this carport for a customer. Plan to build the same here. Only need to buy a few posts and some 2x6 rafters. 24' x 24ft. About 8' tall opening. Will tarp back and sides for now. Can be a carport for work trucks when not used for hay.
It will go behind the security light. To right of box trailer.
You will wish it is higher and be sorry for not going higher for hay. I do realize the cost to go higher,but it is cheaper to go higher now than to build a whole new shed later. Dad built a pole shed back in the 70's and told the guys to put the plates at 12 feet under them. They complained but did so. I want to raise that shed to 17 feet in the future. Not sure whether it is worth it or build a new shed that high instead. The taxes become part of the deal to build a new shed.
Building where we plan to we want to keep it looking nice. Very visible from the road. We do live in the city limits. Even though it's a small town. Really don't want a big hay barn visible from the road. That sorta plays into the height.
Even so, 8' is real short even to put a pickup in. And won't hold much hay. At that size you will be looking for more soon I think.
Please go 10 feet high! I have 2 older buildings 8 feet high and they aren’t worth much, it’s so disappointing to have the roof there but stuff sits outside, can’t get under.
10 feet is too low but at least a pickup can fit in a 10 foot high door. The new 3/4 ton and so forth barely fit in 8 foot, camper top won’t, etc.
8 foot doesn’t cut it.
Paul
I like the 24x24 plan but do agree with others on making it min 10 ft high, plan for the future, my 69 model 4000 Ford is 7'8" to the top of the rain cap when it's open, 5" of stone on the sheds floor and I've got a bent muffler.
I don't think the city will say much about 10 ft height, around here you see a number of 12' sheds in for campers to fit in.
You might look into the steel trusses made by every dick and harry pole barn maker. Those would give you more height in the center without building higher.
What is that strange contraption in the second photo?
I would hate to haul that more than a couple of miles.
Richard
Kevin, I've got to agree on the extra height. roof won't cost any extra. Put it as high as the "police" will overlook. New location is a big improvement over the first spot.
I have two buildings. One I built in 1983. It's 24x32x10. I don't often wish it was higher. Only if I wanted to put my 4320 in with the year-round cab. The other was just built a couple years ago. it's 28x40x8. I use it for a car/pickup garage and added storage. I wish everyday I built it those two feet higher and that's just so I can get my F250 in it. The door is just barely high enough and isn't when the snow gets too high. If I was stacking hay in either one I'd want the 10 footer.
You will be surprised how much hay you can pack into that space. I would put 1x4 slats so you could stack the hay up against the boards.
For tarping the walls off look into used billboard vinyls. Your average poly tarp will last about a month before tearing, and canvas is just out of this world expensive.
The old billboard vinyls have a pipe sleeve in them so you can slide a pipe in top and bottom and strap/stretch them taut so they don't flap. You can get them online.
HI Kevin,
It's always easy for us to spend other peoples money, but....
As others have said make it 10' clearance. I sure wish I had. Now there is no easy way for me to raise it 2' now that it's built.
Another reason to consider making it taller is that the extra height will make it so much easier to add additional storage to either side as needed.
The extra height will also allow you to back a loaded hayrack or truck into protection during a rain etc.
All the best from Ohio. Larry
I have to agree with the 10 foot thing also. I made the mistake of not going high enough on my machine shed and has to cut the exhaust down on a couple of tractors. so they would fit. Never again will I go lower then 10 foot. Plus when it is stacked up on a wagon good chance the hay will sit over 8 foot tall and if you in a hurry and try to get the hay under cover it i not good to have the hay falling off due to the shed being to low
(quoted from post at 15:21:30 08/25/20) For tarping the walls off look into used billboard vinyls. Your average poly tarp will last about a month before tearing, and canvas is just out of this world expensive.
We get them for free around here. Just google "outdoor advertising" for your area. Lamar and others will pop up.
Go visit the local office when your close, walk in and ask for some to use on your farm.
For me the manager wanted to hear I was going to use them on the farm to cover equipment and use as shed curtains.
We went out back and they had a couple of semi flat trailers worth of pallets stack with billboard vinyls.
They do not recycle because they are fiberglass reinforced vinyl. So it costs them to dispose in a landfill.
We tossed as many that would fit in the pickup box.
One cavet they had is they told me to put the printed side down or in so that they were not advertising for free.
I don't do that because the printed side is more UV resistant.
