Hay cutting pattern
grandpa Love
Showcrop asked in my post about my cutting pattern. I clearly need help! Any and all suggestions appreciated. I'm used to bush hogging, just get it cut.
Just looking at my phone, I can?t make much sense out of your map, lol. I always cut 4-6 rounds, then pick the longest straight side in a odd shaped field as my guide. Then go make a cut up the Center of the field parallel to the longest straight side. Then turning to the left, cut back down the say swath I just came up. And turn left at the end and repeat widening out the Center strike until it looks like a shorter drive empty across the end that had the longest side, go down the longest side, and being turning right. This is cutting in strikes, and makes baling hay with a small square baler and a wagon behind much nicer job
Bruce, sounds just like how I try to mow. 6 or 8 rounds, then the longest straight line. I use a wheel rake & those do not like corners. Plus it?s a lot easier to bale straight than it is to turn and bale.
Cut it like you are the one that has to rake and bale it. As long as it is all cut off and you like it, it's ok. I'm supposed to cut from the inside out to protect the wildlife.
My only advice is to start cutting clockwise until the field is cut, then do your trimming around the edges. If/when you screw up and get a fencepost into the mower, it will be on the trim pass and the field will already be cut. My neighbor always insisted on cutting the first pass counterclockwise. Then he always wasted precious time repairing the mower before he could get the rest of the field laid down.
(quoted from post at 09:00:41 04/16/20) My only advice is to start cutting clockwise until the field is cut, then do your trimming around the edges. If/when you screw up and get a fencepost into the mower, it will be on the trim pass and the field will already be cut. My neighbor always insisted on cutting the first pass counterclockwise. Then he always wasted precious time repairing the mower before he could get the rest of the field laid down.
Ditto! Cutting a field in lands especially with a cutter that only has capability of cutting on one side of tractor is a waste of time irregardless due to shape of field. Baling in a straight line is great until one calculates the time wasted on the swooping turns on each end of the field when one isn't making bales
Although cutting with self propelled or center pivot(GN) cutter is a different story
Don't overthink it. Just start on the outside and work your way to the middle.
On large fields try to break it down into rectangular sections that take no more than 8 rounds with the machine to cut. That way you are spending as little time as possible going back and forth across the headlands.
With some practice you'll get an eye for it.
All my fields are odd shaped, I have tried different ways and it always ends up about the same. I try to break it up into more rectangle or square shapes. Starting on the outside and going clockwise is what I usually do. Starting in the middle and working outward SEEMS faster, but I don't think it really is. An old neighbor now passed always told me you have to cut, rake and bale all the same direction, but I have never noticed that it makes any difference, at least not in grass hay.
Bruce has it down. on bigger fields (8+ acres), I make 6 rounds of the outside (counting the backswath), because it takes about that much room when baling or chopping to get lined up with the next windrow, after the outside is picked up. then cutting out from the middle, like Bruce described, will save you a lot of running across empty ground on the headlands. also makes a difference if the field is long and narrow, or more squarish. smaller fields, like a couple acres, just cut from the outside. if there is a tree or swale out in the field that I need to avoid driving into, I circle around it when I get to it, and then turn around and go right back the other way around it again, so there is space to maneuver the tractor and haybine the next time around.
I also second the idea of wearing earmuffs. your ears will thank you later.
Cutting and raking in the same direction was important when you cut with a sickle bar mower, and raked your hay with a roller bar rake. Especially if the roller bar rake was the old 3 bar steel wheel ground drive style. Cut with a haybine, doesn?t make much difference, and pto rakes can beat any hay into a row
I am a fan of just going around CW. First round is CCW. Keep the head engaged to the maximum is my motto. You can't cut hay with the head up is my motto. Corners, just turn them, no jay hooks unless really needed. It looked like you did great to me. Paul
Made absoulty no difference with those rakes either, light hay would rake one pass, turn around and rake second pass going the other way. Who ever said that did not what they were talking about, About as smary about raking hay as prpbly building a space ship. Over 60 years since I started raking hay and grass-legumes makes no difference.
I usually start by going all the way around the outside. Obstacles in the field usually dictate any deviance from the Around and Around and around and Around and around ..............................
When cutting hay with a right hand semi-mounted sickle mower, I always made the first round with the left rear tractor wheel as close as possible to the fence surrounding the field. Then immediately turn around and mow the "back swat". Keep the left rear tractor wheel in the "swat board" track & you will not hit the fence. (Do NOT LOOK AT the fence!) You can then decide how to best cut the rest. In our part of the world, most of our fields are rectangular. That makes decisions simple.
Only seems like the younger ones like just cutting back and forth. I started mowing with a horse drawn mower pulled by a tractor. Only way that could be done was around and around. First piece of machineery I bought was a horse drawn mower in 1959. With those you would have to mow back and forth stop at each end raise cutter bar put out of gear turn and put bar back down and put in gear and how long would that take getting off unit twice for a pass with mower. And those mowers you had to raise bar slightlt to go over the cut hay to mow out the corners that the bar in front of wheels would not do. When the mower came out with wheels in back of bar eliminated that and semi-mount never had that strip left from turning. That is ifyou could make a square corner, turn wheel and hit brake and turn was made. Mow back cut first as that gives you correct starting point for going clockwise. Should be able tosee any obsticales laying in hay to go around them. If you try just going back and forth you have to wait to cut field untill those outside rounds are baled so you are not traveling on them all the time just trampling the hay into ground. And you will never make up lost time traveling empty across ends. The only time back and forth cutting makes any sence is with a self propelled outfit or a hydra-swing that you stay on same side for every cut and then you still have to wait for the outside rounds to get baled. If you have time for waiting from first cutting to baleing before cutting rest of field then might make sence but who has the time to do that. And either your bar mower or your mower-conditioner will make those perfectly square corners you do not have to cut out after rest of field is mowed. This works just as good on any shape field. Only split a field if it is large enough that you want tobale as seperate fields because you could not do it in one day.
The more you cut the field up the more corners and turning you'll have to deal with,no reason I can see for you not to go around the outside and just keep circling.I usually
cut 3 or 4 rounds and then cut the back round,then rake and bale the same way.
Congratulations on your 60 years of experience doing hay. My experience has been different from yours. I have no experience building space ships, but vey extensive experience making hay using both antique horse drawn ground driven equipment right up to new hay equipment built last year, and I stand by what I say. Same thing goes for picking up grain swaths with a combine equipment with a pickup head..
I think certain posters just wait for threads where they can post just to tell everyone they're doing something wrong.
(quoted from post at 09:38:34 04/16/20) The more you cut the field up the more corners and turning you'll have to deal with,no reason I can see for you not to go around the outside and just keep circling.I usually
TF, try it you'll like, it and you will see why everyone does it that way.
I cut around and around with a sickle mower then rake it into straight rows with my new Holland 56 because big balers on 200 hp tractors can?t Turn like a 3020 with 7 foot mower .
The reasons younger guys like going back and forth are self propelled and hydro-swing hay and disc-bines, hard to go around corners with choppers, round balers, kicker balers, and newer hay rakes that do not handle corners very good without missing some hay. Old (50-70 or so years ago) steel wheel rakes did 90 degree plus corners very well making round and round mowing work. Growing up we mowed round and round with a JD no 5 mower on a 1935 JD B and later with a 1946 JD A. When I started chopping most of my hay I went back and forth in lands and later back and forth with a hydro-swing haybine. It makes it handier hauling in using this method. Also if the hay got too dry I wood just leave it and round bale it in the evening or the next day. This way is harder on the ends especially the area towards the exit for the field. One 40 acre field we would end up with a 16' chopper box full on one side near the road exit after 2 12' rounds. If the chopper guy filled the wagon before the end, he would pull out and bring the load to the end. I would park the empty wagon next to the full one so it was close and I would hook up the chopper when I hooked up the full wagon. Every so often the chopper would clean up the abandoned windrows left behind. This field was close to the buildings so I did not need help hauling in. We would start chopping 11:00 AM and usually finish by 5:00 PM so I could milk. 22 -24 loads and maybe 1-3 loads on wagons to unload after milking. I had my JD 4440 on the blower filling my 90' tall Harvestore.
No way is wrong. Whatever makes you happy. Most people have reasons the way they do things.
(quoted from post at 06:16:49 04/16/20) Just looking at my phone, I can?t make much sense out of your map, lol. I always cut 4-6 rounds, then pick the longest straight side in a odd shaped field as my guide. Then go make a cut up the Center of the field parallel to the longest straight side. Then turning to the left, cut back down the say swath I just came up. And turn left at the end and repeat widening out the Center strike until it looks like a shorter drive empty across the end that had the longest side, go down the longest side, and being turning right. This is cutting in strikes, and makes baling hay with a small square baler and a wagon behind much nicer job
I do it exactly like Bruce described. Except I start with 8 rounds because it fits my rake better. I usually cut first round clockwise so I let the tractor find any fallen fence posts, branches or such rather than having the mower eat them.
We have corrugations in our fields for irrigation. Like speed bumps every 30 inches. Two rounds to open it up then back and forth with a self propelled swather. Pull behind 3 rounds to open up.
That's exactly how I cut hay, especially when using a harvester. They don't like turns under load.
Ben
(quoted from post at 09:36:55 04/16/20) Only seems like the younger ones like just cutting back and forth. I started mowing with a horse drawn mower pulled by a tractor. Only way that could be done was around and around. First piece of machineery I bought was a horse drawn mower in 1959. With those you would have to mow back and forth stop at each end raise cutter bar put out of gear turn and put bar back down and put in gear and how long would that take getting off unit twice for a pass with mower. And those mowers you had to raise bar slightlt to go over the cut hay to mow out the corners that the bar in front of wheels would not do. When the mower came out with wheels in back of bar eliminated that and semi-mount never had that strip left from turning. That is ifyou could make a square corner, turn wheel and hit brake and turn was made. Mow back cut first as that gives you correct starting point for going clockwise. Should be able tosee any obsticales laying in hay to go around them. If you try just going back and forth you have to wait to cut field untill those outside rounds are baled so you are not traveling on them all the time just trampling the hay into ground. And you will never make up lost time traveling empty across ends. The only time back and forth cutting makes any sence is with a self propelled outfit or a hydra-swing that you stay on same side for every cut and then you still have to wait for the outside rounds to get baled. If you have time for waiting from first cutting to baleing before cutting rest of field then might make sence but who has the time to do that. And either your bar mower or your mower-conditioner will make those perfectly square corners you do not have to cut out after rest of field is mowed. This works just as good on any shape field. Only split a field if it is large enough that you want tobale as seperate fields because you could not do it in one day.
Leroy, you are exactly right!!! it is the younger ones that like cutting back and forth. I would say that the cut-off for younger is at about 75 right now, LOL. You are right about trampling the hay in the headlands too!!. But if we are making dry hay we are back in a few hours to fluff it out anyway. It makes no difference. The difference that it does make is acres per hour cut. The faster it is cut the sooner it is drying. These days farming is tougher. Margins are tighter. More has to be done faster with less labor. You have to be covering ground when cropping.
I have to agree with svcummins on this one..
Running a big baler and a tractor with m4wd on bigger pieces I catch about every 3rd windrow after its raked.
Anyways I cut the first round counterclockwise (it comes from running a grain combine near trees with an auger hanging out the left side).
I cut 4 rounds to 8 rounds (14 ft new holland)around the outside depending on the size of the piece. We rake 2 to 1 on the heavy stuff or 3 to 1 if its lighter
(quoted from post at 08:03:35 04/16/20) Showcrop asked in my post about my cutting pattern. I clearly need help! Any and all suggestions appreciated. I'm used to bush hogging, just get it cut.
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto1684.jpg">
If that ditch running from the tree to the garden is big enough that it bounces your tractor and equipment around when operating at normal speed I'd lay that field off in 3 sections, start with the section where you come thru the gate mowing clock wise, this puts the tractor next to the ditch, trees and fence, best to find a washout, downed tree limb or fence post with the tractor than with the cutter bar, none of those sections are big enough to get setup for straight back and forth mowing, i'd just go around the field until that section was done then cut out the back swath before moving to the next section, this way should you have problems there's not one strip of uncured hay around the outside swath when the rest of that section is ready to bale.
If that ditch is just a low drain that can easily be crossed split the field into two sections with the 400x100 ft section below the big ditch being the second section.
Some spots I'd leave as I believe in never mowing into a corner that I have to back out of, you waste more time mowing raking and baling those spots than the few bales you'll get are worth.
With your style rake I like to rake 2-3 double windrows (around the field and back) to make room for turning around, then rake back and forth starting at the longest point and working down to the short rows, I've found this is makes raking and baling much easier.
