Hay.... elevator chain question....
Absent Minded Farmer
I can't find the danged manual for it/still looking. So, while I'm being impatient....
How tight or not tight should it be? Should the paddles be dragging on the bottom of the bottom trough on the return trip? That thing sure squeaks & groans a lot. Don't want to get it too tight though.
Also....
Guessing it's like a spreader chain & you have to keep it equally tight on both sides so it runs straight? Looks like it should be that easy, at least.
Mike
Watch your drive sprockets at the bottom when it running. Tighten it enough so the links come straight off the sprockets and don't try to follow them down, causing them to look like they're wanting to double up.
The chain coming off the bottom right sprocket, comes off a bit loose. If I tighten that side down a touch, it starts to run crooked. The sprocket doesn't have any lumps or hooking on the teeth. Think the elevator might have a slight twist in it somewhere.
Mike
Mike
Like has been said, it will start to pile up at the bottom if ran too loose. Other than that, if the chain is staying on run it.
