Haybine speed??
Kawookie
Hi guys kinda a new guy and just wondered if there is a prefered ground speed and rpm that I should be operating my New Holland Haybine at?? Thanks a bunch
I use an Oliver 77 to pull my NH460 and I run it in 1st gear at about 3/4 throttle any fast and I have problem plus its a very old machine so I baby it
that depends how thick your hay is. start cutting it you'll figure it out when the wobble box drive belt starts slipping your going too fast tonight I was using the 400 farmall on a nh488 and 1st gear half throttle was it in second gear it kept slipping the belt and plugging up I usually run in second with the 400 with the 706 I run low 3rd torque ahead half throttle
I use a Ford 5000 in 3rd. Gear at 1650RPM. And pull a NH472.
Bout 6 MPH unless the hay is flat on the ground and leaning away from me. I have to give the reel time to pick it up.
But I put in a new sickle and guards every 300 to 400 acres. Keeps the belt from slipping also.
Gary
I would recommend you start cuttin in 3rd and then go from there. If its real thick then go to second. I would say nothin above 3rd. I cut with an IH 706 and NH 467 in 3rd
If your tach works run at rated rpm speed. If tach does not work about three quarter throttle is a rule of thumb I use. You want the ground speed to match the reel speed. The reel will appear to be rolling through the crop.
I'm curious about how you know the rpm's too. 540 pto on a 5000 is 1900 engine rpm.
I run about 1500-1600 rpm in 4th when clipping pasture, 1800 rpm in hay (also 4th, on a Ford 4600 pulling a NH 489)Can go in 5th in lighter hay, or when I have a nearly new sickle.
For pto speed, go the rated 540 RPM. For ground speed, it depends. Find what works for your conditions. Gearing from one tractor to the next are not gonna jive, so if I say run 1st high (4th) and I run a Massey, it might be 3rd on a Ford or Deere.
Some manuals say to run the reel at the same as ground speed. the one for our Hesston says to run it about 120% of the ground speed. Each feild is different, and so is each tractor/haybine combination.
Donovan from Wisconsin
Well thanks for the info but I was using it today Ford 5600 pulling the 489 in 3rd @ 1600rpm and broke 2 chains that drive the big yellow wheelie thing on the front.. Any ideas why these broke?? They were both recently purchased?? THanks again
