HD 6G Hydraulic
I broke the hydraulic line that goes from the pump (I think it across back of engine to left side of motor???) to the hydraulic control box on right side of operators platform. Since I can't lift the loader my view is limited, I can't see where the line bolts to the pump. Has anyone replaced this line and if so is it something that I have to get under the loader and remove the shield to access/replace?
If anyone has suggestions on how to replace the line I would appreciate any advice.
TIA
Wayne
The left side hose is bolt with 4 capscrews 1/2"and flange and with the front bottom grill removed and remove the belly pan becase the hose should have 5 or 6 clamps to the frame
