school boy
My best friend has an HD3 that we plan to overhaul this summer. Is the engine the same as any of the tractor engines? Also the direction reversal clutch isn't working. Will any of the parts from the two speed clutch on the D series tractors interchange?
Engine is the same as on a smaller D-series tractor. If you have the reverser, it is a shuttle shift, not the hi-lo clutches in the Power Director of farm tractors. They fit in the same housing, just like the shuttle shift on the forklift, based on the D17. But parts are different.
The tranny looks the same as the D-15, but ALL gears are different. I have found NO new gears or shift collars anywhere. Hopefully, it is in good shape.
Dale(MO)
have enough to build a shuttle clutch, parts from flywheel to final drives, entire trans,winch, fuel tank, hyd system,H3 engine(gas)
740 667 6297 coolville ohio
Do you have the spool valve for the 1066 loader? Mine is past the point of repair. If so, what would you consider taking for it?
Thanks,
Dale(MO)
