If you have a good stering cluch adjustement
and and did't turned he should be stuck and if the adjustement is far and you can't give more adjustement he should be shot and you need a good brake adjustement too for turning.
There should be approximately 1 to 2 inches of "free space" between where the turning lever rests and where it starts to engage the steering clutch. You should be able to feel the steering clutch engage as you pull the lever back. If the lever goes all the way back and no tension is felt, something in the steering clutch or release linkage is not working. It could be an internal bearing or linkage....either way, you"ll have to start taking off parts to find the problem. It could also be grease or oil between the clutch disks making them stick together.
