Head gasket Super MTA
pafarmall
Guys i need some help finding a head gasket for a "stock" SMTA. It has a overbore kit but is stock otherwise. The only gaskets i can find are only metal jacketed on one side and i keep blowing the fiber side out. Any idea where i can find a good gasket? seems like the good gaskets are all for big bore engines or are copper. thanks for the help
I have a 10:1 Case engine with a stock gasket, you sure you don't have low sleeves? Lubbock will make and sell you a piece of crap and if it fails they will sell you another pos for full price.
You dont want to use copper for a sleeved engine with a sleeve standout. The gasket will be held up off the block, by the sleeves. You will seal the cyl, you will not seal the water from the oil.
Victor has those double sided gaskets, may have to go to napa to get them, used to get em in every kit, now its the one sided set. Quality huh?
If you go copper, you could have the block decked flat (with the sleeves installed) then the copper will work for you. Even if you built the bore of the gasket to fit around the sleeves, the sleeves may move up and down and disaster will strike when the sleeve breaks and drops down into the crankcase.
You must have a LP head to be blowing the gasket that easy!???
I had the same issue, if you have a Case IH dealer aroung they can get them, price is similar. The Victor Gasket as Full Throttle said work well if you can get one. Mike
Thanks for the info and input. I am checking into whether i can get a victor that isnt part of a kit. The ones in the head gasket sets are definately one sided...why the difference??
I have been pulling againist this so called "stock" MTA for years. The guy that owns it and a a$#. I would put a wooden gasket on it as it would hold up better than the rest of the tractor. You better get that thing put back together if you plan on pulling at Harrisburg. As I keep telling you built it big and be done with it.
