Head Update
Dunk
Update.
Got head surfaced, and got it back.
Set head on tractor, no gasket, started 2 bolts.
Pistons hit head.
UhOh
Now, how to tell exactly where problems are?
Ah, wheel grease sitting close, put light coat on tops of pistons.
Sit head back on, turn over engine remove head.
There is what I needed to know.
Work on head with drill and grindrock.
Do over.
Still hits.
Do over.
Still hits.
But getting a lot better.
Do over.
a total of about 7 or 8 times.
Pistons no longer hit head without gasket.
Finally.
Clean up everything good again.
New Fel-Pro Gasket
Got head sit back on, and bolts snugged down.
Very tired
Quit for day.
Will it hold up?
I don't know!!
One note, before I was thru grinding, I had most all of the tops of the pistons with a light coat of wheel grease, more than is in the picture.
Shuuuah!! That oughter work just FINE!!
Positive clearance is a FINE thing!!
Ya done good!!
duey
(quoted from post at 19:11:58 04/24/09) Shuuuah!! That oughter work just FINE!!
Ya done good!!
duey
I have got to give credit to this FINE forum!!!
Everything that I did, I have read, or at least read ideas tossed out, on this FINE forum.
I'm sure there's a good reason but never heard it, why could the gasket not be doubled? Would 2 not completely mate?
(quoted from post at 19:37:15 04/24/09) I'm sure there's a good reason but never heard it, why could the gasket not be doubled? Would 2 not completely mate?
I have heard folks say to do that, but a blown head gasket was my problem to start with.
I wouldn't feel comfortable squashing doubled fire rings together on the gaskets, I just don't know.
The heads grind easily and quickly, but I took my time, as I didn't want to remove any more than absolutely necessary.
I am not saying that it won't work.
(quoted from post at 22:16:53 04/24/09)
Betcha you blow black snot fer a week :lol:
Won't be the first time!!
Back in my electrician days, we used to wire a lot of very old houses 100+ years.
All of them that had burned coal had this black powder in the attics, I could work on them a day or two, and hopefully git done by then.
Black boogers.
By day 3 or 4, even if I got done on day one, I had a sinus infection that only anti-biotics would cure.
My nose was having trouble dripping.
But this pollen lately has been having some bad effects on me for a month or more.
I have re-wirwed many houses that the whole house was running off of one 30 amp screw in fuse.
A 110 volt meter, and base, only one leg.
Knob, and tube wiring.
The tubes make excellent knife hones, a rough ceramic they are.
I still have a 110v meter base, and meter in the attic, they make beautiful lamps.
I just never got around to making the lamp.
I bet I done 60 touch yer toes, running the 18? head bolts on the wire brush on the grinder cleaning them, and the threads, it kept taking them away from me and slinging them.
The back of my leg muscles are sore from that.
I needed to adjust the "rest".
I do need the exercise though, BAD
It is very good for me, no matter how bad it hurts.
At least that is what I hear.
Yo Smokey,,, it would B nice to know the dept of the valve pockets fer you nail the head on,,, least I would like to know,, just about center were the valves will b in the head
(quoted from post at 07:12:18 04/25/09) Yo Smokey,,, it would B nice to know the dept of the valve pockets fer you nail the head on,,, least I would like to know,, just about center were the valves will b in the head
Too late now Hobo, I have all of the bolts good and snug.
(quoted from post at 22:22:29 04/24/09) Nice work...Have some up and coming plowing to do?
I am behind now on plowing, bush hoging, and no telling what all else.
(quoted from post at 14:20:32 04/25/09)
I/m have'n my own plow day today,,, hope yer head ain't cracked,,, does not look like one spent much time clean'n the combustion chambers
I got her torqued, new oil, filter, etc...
Got the Ole Lady and her daughter to help me set the hood back on her, hooked the gas up, and she fired up.
I let her run for a good 30 minutes, checked the temp of the water in the radiator, 159*, no thermostat, no shroud.
Cur her off, set the hood back off, and re-torqued.
I pulled the wire tube off, as I broke one of the legs off of it, trying to straighten it, and didn't feel like fooling with it.
So I had to wire tie up some wires, put the hood back on and she didn't crank, WTF?!?!?!?
Oh, heck, I only put a small amount of gas in it, as I knew I was going to set the hood back off, I bet it is just low on gas.
Put in gas, fired right up.
Put all hood bolts, and grill on.
Plowed about 45 minutes, and ran out of gas.
Ole Lady is gone after gas.
She is running as good as ever, I am calling it a success!!
[b:d86c1560db][i:d86c1560db]
Good for you Dunk; I knew you could do it. Glad you gotter dun!! :lol:
Gary :D [/i:d86c1560db][/b:d86c1560db]
(quoted from post at 19:14:50 04/25/09) [b:37339a4d21][i:37339a4d21]
Gary :D [/i:37339a4d21][/b:37339a4d21]
Thanks, Gary, it felt good to be riding, instead of bending over....
You know these days, my grinding, is known as a Presidential Solution?
Be careful, somebody will think you're talking about the colored President again! :lol:
(quoted from post at 19:59:40 04/25/09)
Bottom Line....
Presidential Solutions, matter NOT, as long as they work!!!
The way I went it cost less than $40.
The other route would have probably cost about $200.
That is not counting fluids, that would have been the same cost either way.
The last, about 5' of my exaust on my Blazer, in it's former life, was a drive shaft for something, and it is suspended on electric fence wire, it has lasted MANY years.
(quoted from post at 21:29:25 04/25/09)
Its my understanding a Fel-Pro gasket does not require a re torqued,,, least none i have ever dealt with
You are correct in a partial sort of way.
Fel-Pro has been making No Re-torque gaskets for many years for automobiles.
They are some of the most awesome head gaskets.
But this gasket is NOT a no re-torque gasket, I do NOT think they make them for flatheads.
My preference in gaskets for ANYTHING important has always been Fel-Pro for over 30 years.
They couldnt't be beat for the non-cork gaskets for Chevy valve covers.
(quoted from post at 19:14:50 04/25/09) [b:08913f89e8][i:08913f89e8]
Gary :D [/i:08913f89e8][/b:08913f89e8]
Gary, you know why Dunk "gotter done"? Because he jumped in an went to work, rather than try to talk the problem into submission as so many seem to be trying lately! :!: :!:
(quoted from post at 22:36:10 04/25/09)
(quoted from post at 19:14:50 04/25/09) [b:a9fa301113][i:a9fa301113]
Gary :D [/i:a9fa301113][/b:a9fa301113]
Got that right......I have one, in mind right now....just keeps going and going and going!!!! Kinda like the energizer bunny!!! :lol: :lol: [/i:a9fa301113][/b:a9fa301113]
Thanks, guys.
Ell, I needed a running tractor, not a conversation piece.
I hope I can get up to the 6 to 8 hrs of bush hogging that I am way behind on.
I got a GOOD once over on the garden this afternoon.
Like I said, there have been [b:63fa263477]many[/b:63fa263477] posts on this FINE forum, that I had for guidance.
Thank God for you/us guys that are willing to share their experience.
Dayum Dunk as you say, if you ever need a loaner I've got one. Only have three tractors now but on the lookout for more. David.................
(quoted from post at 00:27:15 04/26/09) Dayum Dunk as you say, if you ever need a loaner I've got one. Only have three tractors now but on the lookout for more. David.................
Thanks, Dave!!
(quoted from post at 02:53:13 04/26/09)
Nuttin wrong with cork and the rubber is not a good fix either
The problem is 4 mounting points and a tin cover
Little know to alot of folks is GM has a fix,,, a kit that will pert neer eliminate cover leaks forever
The aftermarket tried to copy it but its a waist of good money to by the chrome straps,,, that bend when tightened down,,, GM's does not,,, they apply a continuations clamp to the cover and will sprang back to original shape when removed
GM Part # 1408516,,, works on must GM engines 4-6 or 8
Takes one kit per cover,,, $18 retail per kit,,, forget cover leaks for the nezt 10 years are more,,, I had a set on a 350 for 15 years,,, not a trace of a leak,,, cork gaskets used 8)
