Header transport kit
Does anyone have a link to a kit that lets you bolt on brackets to make a wagon gear into a header transport? I can't seem to bring up a link to one. I only see the whole header movers which are rather pricey. Thanks.
one fellow here just put a 12" x 12" timber on one side of his wagon....works for him....he transports a 16' flex or a 6 RN with it.
The factory ones we had were just an axle, and a single large box section for the frame. The brackets slide on the box frame, so were adjustable for different headers. The brackets are just craddles for the skid plates to sit in. They need to hold the header at the correct angle for the height of the trailer to make coupling up to the combine easy. Maybe sit the header on the trailer while attached to the combine, make a template of the shape the brackets need to be for the skids to sit in, then make them or get them made. The ones we had, had a kind of hinged G clamp on the end of each bracket that flpped over and tightened down behind the knife to hold the header on.
