headlight bolts
GL59
Hi all, i want to put the headlights back on my to20 but need the mounting bolt for each, can these be bought online or is there a hardware item that will substitute? btw, there are two different clutches for the to20, is there a year or serial no. break point to tell which one is used or do i have to split the tractor to find out?
I think this is the bolt you are referring to. Its a special bolt and I think the same as for the "N" Ford lights. Have seen it for sale in some of the parts catalogs.
yes, that looks like it. if anyone knows the name of that type of bolt it would be most helpful. i"ll search online and post it if i find a source. thanks for the info.
GL59
If you try to drill one of those bolts, drill it slow and don't let the drill bit heat itself up, or allow the metal to get hot which will make it get hard.
The best bet is do it in a drill press with less than 200 RPM.
If you can find a carbide drill bit, (not a cement drill) it will do the job for you.
Brian
