(quoted from post at 20:18:15 12/30/13) So- you're saying a 1000# wheel takes NO MORE hp to turn than a 100# wheel???!! Heavier the wheel, the less power remains to turn the axles. Period. Maybe only a fraction of a hp but it's a fact. Take a tire off your wife's car & push it across the yard. Now a semi tire. Hmmm....
Since you asked I am doing verry well thankyou for asking . I see your learning alot from getting a hold of one of barneys engines to disassemble. you going up to jamisons for the airflow seminar. To add to flywheel it actually matters to what the tire height and weight is. Even a stroker big block with a 4500 stall can need a heavy flexplate if the slicks on the dragster are tall jm2cents(quoted from post at 07:48:33 01/04/14)
It's to bad that his carb issue has caused ML to show his ignorance once again.....oh well won't be the last time. How's it going there pank, they gave some of your allies names the boot for acting stupid over on AC I see....kind of miss someone acting stupid for us over there with cast iron forging facilities and schedule 80 all thread rod ideas.
On the subject of flywheels, it only takes a slight, I mean very slight amount of additional power to rotate a heavy one vs a light one at a particular speed. The more mass that can be contained in the outside diameter of the flywheel the better. If 2 weigh identical on the scale, the one with the lighter center and heavier outside will offer more inertia.
If I am running an unlimited RPM engine, I want to build it so that it will accelerate until the load hits it, at this point the flywheel is going to come into play. I'm going to make it as heavy as possible or practical. This heavy flywheel is also going to help get the tractor off the line by not letting the engine drop so far to get the load rolling. It's harder to accelerate that heavy flywheel, but there's lots of time for the engine to do it.
If I'm making one for a governed RPM tractor that is going to be pulling in some paced class then I'll build a light flywheel. Lets just say you are in a 4mph class and staying low in your RPM range to maintain the pace, as the load comes on and the tires slip it's nice to be able to accelerate the engine slowly to maintain that pace. At a time when the engine is already working hard to maintain it's speed, the additional weight of the flywheel is working against what you are trying to do.
Of course it makes a difference how long it is between the "impulses" of the cylinders firing. A 2 cyl deere with an erratic firing impulse needs more flywheel inertia than a 4 cyl that has an impulse every 180 degrees of rotation, actually you have less than the 180 as the impulse lasts for several degrees. A 6 cyl has closer impulses but there is still a dead spot. Look at a v8 and those engines that race in circle track, the small diameter and light flywheel clutch assemblies that are needed to give them off the corner acceleration. Where that V-8 will have a heavier and larger diameter flywheel when put into a pulling application.
On my low torque high rev engine I want the heaviest flywheel package I can make work. On my high torque governed RPM engine I want a light flywheel, I just need enough to absorb the impulse action and carry it a few degrees until the next one hits.
(quoted from post at 15:37:33 12/31/13)(quoted from post at 20:18:15 12/30/13) So- you're saying a 1000# wheel takes NO MORE hp to turn than a 100# wheel???!! Heavier the wheel, the less power remains to turn the axles. Period. Maybe only a fraction of a hp but it's a fact. Take a tire off your wife's car & push it across the yard. Now a semi tire. Hmmm....
A heavier flywheel gives you more torque.....since going to a heavier, steel flywheel on my G the tractor lugs way better.
