HELP-Bobcat Falls in Lake-HELP
Anonymous-0
I dropped a skid steer off ledge and flooded the engine compartment. It ran for a minute or two while tring to climb out with bucket then shut down. It took on water through the intake, and now it wont turn over. Acts like it is locked up. Can a combustion chamber,or two, be full of water. I heard no knock when it shut down. Please help. Thanks in advance.
Also any IT manuals avalable in PDF for study purpose. Bobcat Kubota 2203
I'm not much help at all for you, but yes - a piston chamber can fill up with water & lock the engine tight 'hydraulicly'.
--->Paul
If it stopped due to hydraulic lock you probably have at least one bent rod. Hopefully it won't have bent the crank but it may need checking out.
If it stopped first and then flooded you will need to remove the injector or tighten down the valve just enough to carefully remove all water from the combustion chamber and inlet manifold. If it fires against a hydraulic lock you will likely bend a rod.
Regards, RAB
Take the glow plugs out and spin it over. If the water is what caused it to stop running it's likely you will have a bent rod.
Yup. Might be easier to just pull the engine now because like the others say, you've probably got atleast 1 bent rod.
Donovan from Wisconsin
it's "hydraulic'd"- possible bottom end damage, but you won't know till you spin the water out.
i've seen PILEs of lil' "tuner dudes" with Hotrod Hondas lock 'em up this way when their cold air intake kits suck up a rain puddle. This is about the only thing that will kill a Civic engine!
