OK here is the problem, its my first time trying to run the sprayer after buying it last fall. I'm new to spraying as I always had it custom done.
It has the Raven controls and I've sort of just figured out how that works. I have all the books on it, but what it shows and says in the book and whats on the sprayer look like two different things so thats where I'm having a big problem, and right now no matter what I cant seem to get the water coming out of the sprayer, I have it all hooked up, and power to everything, but to me it seems like some level isn't turned right, but I have no clue which needs to be where.
Also it doesn't help that my neighbor who was suppose to show me how to run it is gone for a week, and every other farmer in the county is out in the fields now. I posted a few photos below that shows what I'm working with, I put #s by each lever so if you know what that lever does it makes it a little simple to understand it and how it should be put in order to work.
Its basically a question of: what do you do to run your sprayer? What are the Raven settings and lever settings on the sprayer needed in order for it to work?
Thanks for any and all help!
