Help Identifying John Deere/Van Brunt Drill
OlGord
Hi...First post and figured someone here can help me out. I bought this drill at auction yesterday. I thought it would be good for planting winter wheat as a cover for some ladino clover. Anyway, I"m wondering if someone can identify the model so I can try and find a manual for the thing. There are 13 disc blades at 7 inches. Thanks, Gordy
Looks like a model FB. Should be marked on the front of small seed box or on rear of fert. box. Marking is painted on.
Good luck if you ar planting wheat behind a soybean crop. Those single disk openers don't like bean stubble.
We did that for years, wheat after beans with single disk openers with no problems, just have to properly prepair the ground.
Look on the side caps of the big box(s), can't remember if it's left or right, but one should have a tag, with model and serial info.
The FB that I had did not have a tag. The model and serial were painted on both the box and the frame. Now get this,the serial numbers did not match, evidently when new the dealer had 2 drills from a couple of thousand serial numbers apart and when assembling them they grabed the box from one and frame from the other.
I never had problems. Combine had a straw chopper. I spread fertilizer on stubble, then pulled a field cultivator with a packer hung on behind over it, drill worked just fine. Planting rye in corn stalks in the fall, that was different. Unless you moldboarded them under, you just weren't gonna do it with that FB.
