TheRobertRalph
I finally broke down and bought a new starter. This is an aftermarket and I need a bit of help to get it wired up since it is just a little different than the JD stock one.
I have enclosed pictures of the current one and a referece to the old one.
24v System. There are two big wires coming from batteries. The negative goes to the top post on the solenoid.
1) The + cable went to the side of the old starter on a lug. Then another lug came out of the starter with a bent piece of metal connecting it to the bottom lug of the solenoid. Can I just hook the + to the bottom lug of the new solenoid? My instict is that I cannot. Also, it has a bent piece of metal going from that bottom lug on the solenoid to the side but there is no lug on the side to mount the + cable to.
2) I'm curious to understand the smaller lugs (1/4"?). There is one labeled "S" and I believe that is the starting switch? What is the other one for? There was a grey wire going from it to the + lug on the side of starter before.
Old Starter wiring:
New:
This post was edited by TheRobertRalph on 06/12/2022 at 06:14 am.
Old Starter wiring:
New:
