Hello, been using my white 2-105 to load hay for the first time this year and noticed the hydraulics slower then normal, also seems be have trouble lifting 1000lb bales. Worse when its warm, today after running for 2 hours it wouldnt even lift a bale over half way up. Have to throttle up to 17 - 1800 to pickup one of these bales, before it would just idle and lift easy. Another issue that just came up is the hydraulics are really choppy. Symptom 3 has been going one for sometime but the loader leaks down right after i release the valve, it drops about 6" then stops, never really worried me but seems like thats getting worse too. Pump is about 5 years old and likely has about 1000hrs on it. It is a A & I pump not oem. Oil is full and isnt foamy, small leaks on the loader frame and quick connects nothings worse then last year. Going to pickup hydraulic filter tomorrow, does this one also have a suction screen? Someone told me to screw in a bypass screw located on the front of the pump until it makes pump work then back off half turn, thoughts?
any help is appreciated as always, thanks!!
