Kind of orange color, no markings on it. Broke a spindle, no one local can help me. If I can get make and model, I can start there. Solid heavy angle iron frame. Will try and add some pictures. Thanks for any help.
Just take your old pcs to a machine shop and have them make one up or better still if you have a buddy with a lathe? Probably just made from 1018 but 1045 might be safer? That looks like a relatively easy piece to make.Kind of orange color, no markings on it. Broke a spindle, no one local can help me. If I can get make and model, I can start there. Solid heavy angle iron frame. Will try and add some pictures. Thanks for any help.
Yeah, thinking I may have to, kind of worried about the cross hole bolt, getting drilled perfect.Just take your old pcs to a machine shop and have them make one up or better still if you have a buddy with a lathe? Probably just made from 1018 but 1045 might be safer? That looks like a relatively easy piece to make.
Where are you located?Yeah, thinking I may have to, kind of worried about the cross hole bolt, getting drilled perfect.
WOW are you a big help! I actually dropped it in a hole that caved in from an old oilfield pipeline. Now David form Kansas, just go away! I have a local machine shop building one today. This IH disc was still made in 1988, thought it should have parts available for it. Thanks for all that had info for me. ( No not you David from Kansas )I tend to be a skeptical person. Was this all brought on by someone who purchased a product by a certain manufacturer because he could buy it a couple of hundred dollars less than brand X? Look at the size and design of the hubs and wheels. Really small hubs with 4 bolt wheels. And then add thousands of pounds of extra weight and wonder why the bearings/hubs fail.
