down_right
So I have just under a dozen (I think 10 or 11) of these old gandy box units, as well as a lot of the mounting brackets, hose/tube/shute bracket that hold the discharge hoses in place, etc (list towards end of post).
I only need to use these for fertilizing maybe 2 acres of research crop plots, so it's not like I have 500 acres I expect to use these for. But I do need to get them working. I have 4 row plots, so they will be mounted likely on a small (homemade) 4 or 5 row diamond bar cultivator
My main questions are:
1) what is the best way to mount these units to achieve my need of working on a 4 row cultivator (# of boxes, placement, which models of box units, what # of discharge shutes/metering units should I use, and how do I place them?)
2) what kind of motor replacement will I need to have enough power to sufficiently apply the fertilizer?
3) how many motors? 1 on each end of the toolbar, or just one really strong motor? What kinda specs should I be looking for?
4) help with decoding the electrical wiring of these types of motors
On the cultivator I have:
- 1 bar for the gauge wheels, self explanatory
- 1 bar for the "main"/large cultivator ditchers/points things on shanks. Might also have smaller ditcher/"shovels" also on shanks (or maybe they're on a separate bar, can't remember)
- 1 bar for more of those small points mounted on shanks. Each row has a total of 2, 1 on each side of the row positioned in a way so that the dirt/bed is opened slightly for side dressing the fertilizer
- 1 bar for the gandy units
Supplies I have:
A) Gandy box units:
1A) Model # S902EM: x4
2A) Model # S901 P: x4
3A) Model # S901EM: x2
B) metering/roll-ie-over-things (attach at bottom of box units:
1B) 1 hole/hose unit: x6
2B) 2 hole/hose unit: x5
3B) 3 hole/hose unit: x2
C) Motors: total of 3 (all need replacements I think) only 1 of them are actual gandy brand motors. From what I remember in trying to lookup serial/etc #s on the motor, they are basically (or literally) just windshield wiper motors
1C) x2 motors that I think originally came off a IHC combine or similar. I think I burnt them up a few years back when I had absolutely ZERO electrical/mechanical know-how knowledge
2C) x1 Gandy brand; The following info is from the motor's body:
>>12v electric motor (2 wire).
>>black wire is negative
>>green wire is positive
>>Drive sprocket on the motor must turn COUNTER CLOCKWISE
>>Model #EM45951
E) a bunch of 5/8" all thread rod, or otherwise hollow pipe/rod of similar size that is used to keep multiple boxes running synchronized off of one motor mounted on the end unit
Not sure if this motor unit is still functional (I still don't really understand how wiring these windshield wiper-type motors work). I don't really grasp the concept of what all the terminals with one letter Alphabet labels mean, or how to connect them properly. I just sort of randomly connected things last time I tried to use these motors until they started turning, then added a switch controller running to inside of my cab. To make it more complicated, I think both types of motors had slightly different labels and terminals
The "IHC" motors have following terminals, in two clustered groups:
Group 1:
H: (from my tinkering, I believe this was the "high"/fast mode
R: No idea. Looking online gives different or vague, conflicting info. Could be relay, reverse, roobiedoobiedoodbiedoo FAIK, ffs
G: Ground? The motor had a green wire from inside the motor connected to this spade terminal
L: No idea, this mightve been one of the terminals that didn't have anything connected to it when I originally got it. As I think now, I wonder if themis L terminal means "Load"? Maybe it's a shot at me, meaning "loser"? Or, "lol (loser)"?!?questionmarkexclaimationpointquestionmark
Group 2: P
General consensus seems to be this is the "Park" terminal. I haven't the faintest idea wtf that means, other than the people who decided on these terms are obviously partake in some serious sadomasochistism
Supplies I have:
A) Gandy box units:
>>Model #EM45951
Group 1:
Group 2: P
