help with soil test
chuck t
First time with this thing. Doing food plots for deer. Test says salt pH is 5.9. Limestone suggestion listed under Effective Neutralizing Material is 360. says to determine limesone needed in tona/acre, divide ENM requirement by the guarantee of you limestone dealer. Whis the a typical guarantee? What is a ballpark figure in tons/acre I will need?
I looked up some soil tests and the recommendations. I had one from a field that had not been kept up when I took it over a few years ago and the pH was 5.8. The lime recommendation was two tons to the acre of high mag lime. Another test was 6.5 they recommended one and a half tons per acre. Every recommendation I have ever had has been by half ton increments so I don't think you need to worry about getting too exact. It's not like fertilizer.
add one ton per acre and test again in one year' with ph of 5.8 this should bring ph to 7 which is nautral. lime is the cheapest bang for your buck.
In my part of the country you just want to be above 6.0, so wouldn't be far off.
--->Paul
I always heard that a ton per acre per year is about all you can effectively do and will raise the ph by about 1. 5.6 will move closer to 6.6
Law of dimishing returns
I'd go with a ton per acre with hydrated lime with extra calcium and mag. Its the fastest acting type. It needs to be spread and incorporated into the soil quickly for the best outcome
Any one have any thoughts on this
What you are looking for is the calcium carbonate equivalent of the lime. That being said you shouldn't need more than two tons per acre unless you have really bad lime. Most CACO3 equivalents will be from 85% to 100%.
The other things you are dealing with are the CEC of your soil and the crop you are going to grow. Grass crops do best in soils that are 5.8 to 6.2pH. Legume crops are best from 6.4 to 6.8pH.
In Illinois we generally shoot for a 6.2 pH to compromise between the corn and soybeans that we grow.
We use a rec mix it is a bi product from the steel mill with a high mag content. meets all requirements for ag lime costs us$4 a ton and $4 ton to deliver. As many have said 2 ton to the acre is the most you can apply effictively with out working it into the soil. I am in Pa we buy soil sample bags from the penstate extension office there is one in most counties so it is close or you can order on line they are about 10.00 a bag take the sample tell them what you want to grow include rotation if you are rotating and they eill send back a report with all the results and there recomendations. seems to work well
my brother plants those horse kinda radishes and other deer tidbits in whatever the soil is out there, stuff grows jsut fine and deer pull them out of the ground to eat them
he originally planned all sorts of hard work out there then got sensible, spends his time fishing instead
up to you
